Введение
If the camera is showing a black screen or the camera does not take a picture.
Выберете то, что вам нужно
Pry open the back case to get to the back cover.
Remove eight 5mm screws with a PH0 screw.
Pry open the back cover with a plastic opening tool.
Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
Lift the battery up and remove it from the phone.
Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
Lift the front camera out of the phone.
2 участников успешно повторили данное руководство.
