Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The speaker has no sound. This guide will help to replace the speaker.
Запчасти
Детали не указаны.
  1. Pry open the back case to get to the back cover. Remove eight 5mm screws with a PH0 screwdriver. Pry open  the  back cover with a plastic opening tool.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screwdriver.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable. Lift the battery up and remove it from the phone. Lift the battery up and remove it from the phone.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. Unplug wires with plastic opening tool  by pulling wires to the side. Unplug wires with plastic opening tool  by pulling wires to the side. Unplug wires with plastic opening tool  by pulling wires to the side.
    • Unplug wires with plastic opening tool by pulling wires to the side.
  4. Remove front speaker by using metal tweezers. Remove front speaker by using metal tweezers.
    • Remove front speaker by using metal tweezers.
Заключение
2 участников успешно повторили данное руководство.
omar
Участник с: 02.10.2018
717 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S2-G3, Munoz Fall 2018 Участник Eastern Washington University, Team S2-G3, Munoz Fall 2018
EWU-MUNOZ-F18S2G3
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 70
