Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If your ZTE Tempo smartphone (model 9131) isn’t producing clear audio—distorted, intermittent, or no sound—through headphones or auxiliary speakers, use this guide to replace the headphone port (also known as a jack).
The headphone port transmits audio to external speakers through an auxiliary cord. A faulty headphone port will transmit distorted audio or no audio at all.
Before using this guide, inspect the headphone port for debris that may be interfering with sound quality. Typically, a small buildup of dust can be removed using an ESD-safe brush or small dust blower. Be sure to test a few sets of headphones or auxiliary cords with your device to confirm that the faulty part is coming from the ZTE Tempo’s headphone port.
Step 5 requires you to remove the circuit board from the device. From there, you will need to desolder the surface-mounted headphone jack and solder a new one in place.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Запчасти
Детали не указаны.
  1. Pry open the back case to get to the back cover. Remove eight 5mm screws with a PH0 screw.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. Unplug wires by pushing up with the plastic opening tool Unplug wires by pushing up with the plastic opening tool Unplug wires by pushing up with the plastic opening tool
    • Unplug wires by pushing up with the plastic opening tool
  3. Push up with the plastic opening tool to remove the motherboard. Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
    • Push up with the plastic opening tool to remove the motherboard.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
  4. Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
    • Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
  5. Desolder and remove in front of the motherboard. Desolder and remove in front of the motherboard.
    • Desolder and remove in front of the motherboard.
Заключение
2 участников успешно повторили данное руководство.
omar
Участник с: 02.10.2018
717 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S2-G3, Munoz Fall 2018 Участник Eastern Washington University, Team S2-G3, Munoz Fall 2018
EWU-MUNOZ-F18S2G3
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 93
