Введение
If the back camera is showing a black screen or the camera does not take a picture.
  1. Pry open the back case to get to the back cover. Remove eight 5mm screws with a PH0 screw.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  4. Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable. Lift the rear camera out of the phone.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
Заключение
omar
Участник с: 02.10.2018
717 Репутация
Автор 5 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 70
