Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace the charging/AUX board in your ZTE Tempo X smartphone.
Запчасти
Детали не указаны.
  1. Remove back cover using the divot provided. Remove back cover using the divot provided.
    • Remove back cover using the divot provided.
  2. Find the divot near the bottom of the battery and remove the battery from the device. Find the divot near the bottom of the battery and remove the battery from the device.
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the sixteen 3mm screws using the Phillips #000 screwdriver. Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  5. Take off the second back cover, lifting from the bottom of the device to the top. Take off the second back cover, lifting from the bottom of the device to the top.
    • Take off the second back cover, lifting from the bottom of the device to the top.
  6. Using a spudger, unclip the board from the phone at the places highlighted. Using a spudger, unclip the board from the phone at the places highlighted. Using a spudger, unclip the board from the phone at the places highlighted.
    • Using a spudger, unclip the board from the phone at the places highlighted.
  7. Use the spudger to remove the board from the phone. The board is held by glue so there will be resistance when detaching it from the phone. The board is held by glue so there will be resistance when detaching it from the phone.
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
Заключение
Conager Robb
Участник с: 21.09.2018
592 Репутация
Автор 5 руководств
Команда
University of North Texas, Team S5-G2, Thompson Fall 2018 Участник University of North Texas, Team S5-G2, Thompson Fall 2018
UNT-THOMPSON-F18S5G2
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 168
