Введение
Use the guide to safely replace the peel and present system with the help of a phillips head screwdriver set.
Выберете то, что вам нужно
Orient the printer so that the bottom is facing up.
Remove the three P1 9mm screws located on the bottom of the printer and remove the lower unit.
Disconnect the harness.
Thread the harness through the hole on the right hand side.
Заключение
