Введение
If the motherboard is installed properly and the system is still not functioning, the motherboard may be dead, which means it's time to replace it.
Выберете то, что вам нужно
While wearing your antistatic wristband. Using a plastic spudger, remove the back casing of your tablet.
Using a #000 1.5 mm Phillips screwdriver, remove the screws along the inside of the device.
Carefully disconnect the wires from the motherboard by rocking them back and forth until they come out.
Afterwards, you should have a fully functioning device.
