Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace a damaged camera on the Zeki TBQG884B tablet.
Запчасти
Детали не указаны.
  1. Remove the two screws from the end of the device where the ports are located. Remove the two screws from the end of the device where the ports are located.
    • Remove the two screws from the end of the device where the ports are located.
  2. Rest the tablet on the glass face.
    • Rest the tablet on the glass face.
    • Insert the tip of a plastic opening tool into the small gap, between the grey and white plastic. Pry it open, (you should hear the clips opening up).
    • Gently work your way around the perimeter of the tablet's edge.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Separate the back and face plates. Remove any tape on the speaker, and detach the speaker from the back plate.
    • Separate the back and face plates.
    • Remove any tape on the speaker, and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  5. Open the ZIF connector, the black locker part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera. The camera is located on the top left, above the motherboard.
    • Open the ZIF connector, the black locker part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Remove it, and peel the camera off with tweezers for safety.
Заключение
2 участников успешно повторили данное руководство.
Natalie Holm
Участник с: 16.09.2015
137 Репутация
1 руководство автора
Команда
IUPUI, Team 1-3, Harley Fall 2015 Участник IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 166
