Zeki TBQG884B Digitizer Touch Screen
Выберете то, что вам нужно
  1. Zeki TBQG884B Digitizer Touch Screen, Rear Case: шаг 1, изображение 1 из 2 Zeki TBQG884B Digitizer Touch Screen, Rear Case: шаг 1, изображение 2 из 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Digitizer Touch Screen: шаг 2, изображение 1 из 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Digitizer Touch Screen: шаг 3, изображение 1 из 2 Zeki TBQG884B Digitizer Touch Screen: шаг 3, изображение 2 из 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Digitizer Touch Screen, Motherboard: шаг 4, изображение 1 из 1
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B Digitizer Touch Screen: шаг 5, изображение 1 из 1
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B Digitizer Touch Screen: шаг 6, изображение 1 из 1
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B Digitizer Touch Screen: шаг 7, изображение 1 из 1
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B Digitizer Touch Screen: шаг 8, изображение 1 из 1
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
  9. Zeki TBQG884B Digitizer Touch Screen, LCD Screen: шаг 9, изображение 1 из 1
    • Use an opening tool to detach the clip between the front frame, and the metal loader.
    • There are several clips on each side of the frame. Detach ALL of them before you open the loader.
  10. Zeki TBQG884B Digitizer Touch Screen: шаг 10, изображение 1 из 1
    • Lift the metal loader up and separate it from the LCD screen.
    • Detach each piece slowly to avoid damaging or dropping any fragile parts.
  11. Zeki TBQG884B Digitizer Touch Screen, Digitizer Touch Screen: шаг 11, изображение 1 из 1
    • Separate the display from the digitizer.
Заключение
Еще один человек закончил это руководство.
David Wyman
Участник с: 09/16/15
343 Репутация
Автор 3 руководств
Команда
IUPUI, Team 1-3, Harley Fall 2015 Участник IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 800
