Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide is a step-by-step process of replacing the LCD screen. The screen is connected directly to the motherboard, and assembled with the front frame. Look at the teardown guide for instructions on general disassembly.
Инструменты
Инструменты не указаны.
Запчасти
  1. Remove the two screws from the end of the device where the ports are located. Remove the two screws from the end of the device where the ports are located.
    • Remove the two screws from the end of the device where the ports are located.
  2. Rest the tablet on the glass face.
    • Rest the tablet on the glass face.
    • Insert the tip of a plastic opening tool into the small gap, between the grey and white plastic. Pry it open, (you should hear the clips opening up).
    • Gently work your way around the perimeter of the tablet's edge.
  3. Separate the back and face plates. Remove any tape on the speaker, and detach the speaker from the back plate.
    • Separate the back and face plates.
    • Remove any tape on the speaker, and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Remove the Wi-Fi antenna element, which is highlighted by red in the picture,  from the front plate.
    • Remove the Wi-Fi antenna element, which is highlighted by red in the picture, from the front plate.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. Use the same screw driver as the previous step, and unscrew three screws. (Circled in the figure.)
    • Use the same screw driver as the previous step, and unscrew three screws. (Circled in the figure.)
  7. Open the ZIF connector. It will look like a black locker, covering a wire ribbon. Then, remove the wire ribbon that connects the motherboard, and the screen.
    • Open the ZIF connector. It will look like a black locker, covering a wire ribbon. Then, remove the wire ribbon that connects the motherboard, and the screen.
  8. Remove the other wire ribbon on the opposite side of the motherboard.
    • Remove the other wire ribbon on the opposite side of the motherboard.
  9. Now, remove the motherboard and replace it with a new one.
    • Now, remove the motherboard and replace it with a new one.
    • Be careful not to damage the battery, or the speaker wires. They are soldered onto the motherboard.
  10. Use an opening tool to detach the clip between the front frame, and the metal loader.
    • Use an opening tool to detach the clip between the front frame, and the metal loader.
    • There are several clips on each side of the frame. Detach ALL of them before you open the loader.
  11. Open the loader, and detach the LCD screen.
    • Open the loader, and detach the LCD screen.
    • This assembly contains three separate pieces. Detach the display slowly, to aviod dropping any o
Заключение
2 участников успешно повторили данное руководство.
David Wyman
Участник с: 16.09.2015
343 Репутация
Автор 3 руководств
Команда
IUPUI, Team 1-3, Harley Fall 2015 Участник IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,006
