Введение
Before you begin this guide, make sure to have the proper tools. You will need a spudger, and a phillips head #00 screwdriver. If you're having trouble with the battery in your device, removing the back panel is one of the first steps in replacing the battery.
Выберете то, что вам нужно
Remove the two screws on the bottom using a Phillips #00 screwdriver.
2 участников успешно повторили данное руководство.
