Zenithink ZTPAD ZT280 C91 Front Panel Replacement
Выберете то, что вам нужно
  1. Zenithink ZTPAD ZT280 C91 Front Panel Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 2, изображение 1 из 3 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 2, изображение 2 из 3 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 2, изображение 3 из 3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Zenithink ZTPAD ZT280 C91 Front Panel Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 4, изображение 1 из 1
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 5, изображение 1 из 1
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 6, изображение 1 из 1
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 7, изображение 1 из 2 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 7, изображение 2 из 2
    • Slide back the plastic latch for the camera cable.
  8. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 8, изображение 1 из 1
    • Peel back the reflective tape.
  9. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 9, изображение 1 из 2 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 9, изображение 2 из 2
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Zenithink ZTPAD ZT280 C91 Front Panel Replacement, Front Panel: шаг 10, изображение 1 из 1
    • Remove the four highlighted screws using a Phillips #1 screwdriver.
    • For differentiation purposes, these screws are 4mm long and have a larger head than the rest of the screws.
  11. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: шаг 11, изображение 1 из 1
    • Starting from the top, slowly lift everything up out of the front panel.
    • Remove the front panel off of the device.
    • Be careful not to damage the ports along the bottom.
Заключение
Еще один человек закончил это руководство.
Keelie Beach
Участник с: 09/21/18
435 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S6-G1, Thompson Fall 2018 Участник University of North Texas, Team S6-G1, Thompson Fall 2018
UNT-THOMPSON-F18S6G1
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 129
