Введение
Be sure to follow the prerequisite guides before removing the front panel. Skipping any of the guides can lead to damage to your device.
Выберете то, что вам нужно
Remove the two screws on the bottom using a Phillips #00 screwdriver.
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
Slide back the plastic latch for the main display cable.
Carefully unplug the cable with tweezers.
Slide back the plastic latch for the camera cable.
Remove the four highlighted screws using a Phillips #1 screwdriver.
Starting from the top, slowly lift everything up out of the front panel.
Remove the front panel off of the device.
Еще один человек закончил это руководство.
