Введение
In the process of disconnecting the motherboard you will begin with taking off 4 screws with a phillips screwdriver. Once that is done you should be careful with disconnecting all the cables connected to the board, making sure you don't tear any of the wires.
Выберете то, что вам нужно
Remove the two screws on the bottom using a Phillips #00 screwdriver.
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
Slide back the plastic latch for the main display cable.
Carefully unplug the cable with tweezers.
Slide back the plastic latch for the camera cable.
2 участников успешно повторили данное руководство.
