Введение
If your Zerodate T26 mouse has a broken scroll wheel or a scroll wheel that is too dirty to clean without disassembly, then this step-by-step guide on the replacement of the scroll wheel is for you! All you need is a simple plastic opening tool to pry the top and a Phillips #00 screwdriver to remove the plates. Replacement scroll wheels can be ordered online.
Выберете то, что вам нужно
Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
Carefully pull the middle shell apart from the bottom plate.
The circuit board should then be visible and attached to the bottom plate.
Еще один человек закончил это руководство.
