Введение
The visible parts of the input jacks are located on the top sides of the device. The top left side contains inputs 1 and 2 while the top right side contains inputs 3 and 4. To replace the inputs, the removal of the button circuit board and the motherboard are required.
Выберете то, что вам нужно
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
With the bottom of the device on a table, lift the top of the device and gently place it aside.
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
Set the button board aside.
Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
2 участников успешно повторили данное руководство.
