Введение
The only requirements for this replacement guide are the right tools, new battery terminals, and device ready before starting the guide. Terminals should be replaced when the device stops powering on despite the replacement of new batteries or due to the corrosion of terminals.
Выберете то, что вам нужно
Place device on table facing down.
Remove the battery cover, with index finger press protruding tab towards "OPEN".
If batteries are present, remove them in order to reveal the terminals at the bottom of the device.
With the flat end of the black plastic spudger, pry the terminal away from the case.
Use the small blue plastic opening tool to lift the terminal out of the device. Repeat for the adjacent terminal.
For the terminals directly connected to the motherboard, unscrew eight (PH #1), 9 mm screws (two located on the top back side, two in the center of back side of device right above the battery cover, and four under the rubber feet).
Place device face up and remove the four knobs using the flat end of the plastic opening tool.
Unscrew three (PH #1), 7mm screws from the button board near the display and gently flip over.
Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
Set the button board aside.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect wire from motherboard using tweezers.
Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
Gently remove three ribbon connectors from the base of the device. One is connected to the mic connector, the other two are on the top of the device next to the "LINE OUT" plug-in (directly behind the device display screen).
Taking care not to damage other components on the motherboard, use a soldering iron to undo the soldering that holds the terminals to the motherboard.
Flip motherboard over and remove the black tape covering the battery terminal.
Replace with new terminal.
Resolder the terminals to the motherboard.
4 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Where to buy the wire battery contact part?
