Введение
The power switch is located on the bottom, left side of the device. Connected to the switch is its circuit. When the switch doesn't work, it means that the circuit will have to be replaced. This will require the button board, as well as the motherboard, to be removed in order to reach the circuit.
Выберете то, что вам нужно
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
With the bottom of the device on a table, lift the top of the device and gently place it aside.
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
Set the button board aside.
Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
Use tweezers to lift power switch circuit out of device by the plastic ribbon connection.
Replace the power switch circuit.
Еще один человек закончил это руководство.
5 Комментариев
where can i buy the power switch?
Are the parts available anywhere?
If anybody still needs parts, you can get them here: https://shop.audiotronic.fr/en/61-h6
You get get pretty much all the Parrrts for Zoom devices here:
https://shop.sonj.fr/en/3-zoom
