Введение
Step by step instruction to replace the lower jaw of the dinosaur.
Выберете то, что вам нужно
Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
Gently remove the entire bottom jaw piece.
Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
Using a spudger, gently pry the tongue out of the mouth.
