Введение
Is your phone’s touch screen not working correctly or not responding to your touch? Use this guide to replace your screen and return your device to a working state.
Выберете то, что вам нужно
Remove the back cover using the notch at the bottom of the device.
Pull the back cover from the front panel gently to remove it.
Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
5 участников успешно повторили данное руководство.
Один комментарий
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
