Введение
Are you going to throw away your expensive massage pillow just because the heater is broken? Here is a simple guide to replace your broken heater so that your massage pillow can work again.
Выберете то, что вам нужно
Unzip the cover. You can locate the zipper at the back of the massage pillow.
Take out the pillow so that you can manage the heater completely.
Use a Phillips JIS #1 screwdriver to remove the screw at the center of the heater.
Remove the entire heater from the pillow.
You can see a green circuit board after removing the heater.
Using the Phillips JIS #1 screwdriver, remove the three screws circled in the picture.
Now you can take out the circuit board. There will be two wires attached to the circuit board.
If you prefer, you can clean the circuit board gently with dry tissues to remove the sticky lubricant.
Using your soldering station, remove the wires from the circuit board.
Now, you can separate the circuit board completely to replace with a new heater.
Еще один человек закончил это руководство.
2 Комментариев
Hi YuChen, nice work! Do you know from where I can find the switch for this heater? If you can tell me the part number, I can try looking it up on eBay. Thanks!
