Введение
IDES2323
Выберете то, что вам нужно
Remove the seven screws on the top, four can be seen in the picture, and there are three similar screws on the opposite side.
Note: Disassembly requires the use of a special screwdriver, as shown in the picture.
Remove the rubber cover, then loosen the two internal phillips screws to release the fan and heating wire.
Pry open the two knobs (they are plugged in), you can see two screws on each side, unscrew them to remove the gear switch and temperature switch.
Unscrew these two screws to separate the upper and lower parts.
Pallets require special tools to separate.
As shown at the bottom, just unscrew all the phillips screws.
Note: All terminals can be pulled out only by pressing the part shown in Figure 2 with a small or a tool, and should not use brute force.
当重新组装你的设备时,请按照说明的相反顺序进行操作。
