Введение
All you need for removal of the wheel is a Phillips head screwdriver and a few minutes. bObi Pet's cleaning tool, paper towel, and compressed air are optional if cleaning the wheel.
Выберете то, что вам нужно
To start, turn bObi Pet's side power switch to OFF and flip her over so the wheels point up.
Remove bObi Pet’s front wheel. Grip it with your hand and pull up, using a screwdriver for leverage.
You may remove and clean the smaller wheel on bObi Pet’s wheel piece.
To detach it, grip firmly and pull. Once again, you may use the screwdriver for this step.
Flip the wheel over and remove the 2 screws holding the wheel piece together.
Then pop the outer casing open and you'll be able to clean the front wheel's interior with bObi Pet's cleaning tool or compressed air.
After cleaning the inside of the wheel piece, replace the spring inside.
Then, align the edges of its outer casing.
Hold the wheel piece together while you reinstall the 2 screws.
You may replace the small wheel on the other side of the front wheel piece, opposite the screws.
Lastly, place the front wheel back in its space on bObi Pet.
Push down firmly to lock the wheel in place.
Congratulations on completing bObi Pet's front wheel disassembly!
