Введение
This guide will teach you how to remove, clean, and replace the front wheel on bObi.
Выберете то, что вам нужно
Turn the front wheel so it faces bObi's front touch sensors.
Grip the wheel and pull straight up.
To disassemble and deep clean the wheel, remove two small screws found on the bottom of the wheel. Then you can open it.
Grip the actual wheel and pull up to detach and clean beneath it. Use the screwdriver as leverage if you have difficulty separating the parts.
After cleaning, replace the small spring piece inside the wheel.
Hold the wheel cover back together and install the two screws.
Place the small wheel back in its space and apply pressure until it reattaches.
Place the wheel back in bObi. Make sure it faces in the same way as it did when removing (wheel closer to bObi's front).
Push down and the wheel will attach to bObi.
