Выберете то, что вам нужно
To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
The location of the other two screws are marked in red.
After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
Desolder the yellow and black wires that connect the solar panel to the circuit board.
Remove the solar panel by pressing on the mounting clips (underneath fingers) using the spudger.
Solder the wires to the solar panel (positive to positive, negative to negative).
Еще один человек закончил это руководство.
