eMac Optical Drive Removal
Выберете то, что вам нужно
  1. eMac Optical Drive Removal, Door Removal: шаг 1, изображение 1 из 3 eMac Optical Drive Removal, Door Removal: шаг 1, изображение 2 из 3 eMac Optical Drive Removal, Door Removal: шаг 1, изображение 3 из 3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Optical Drive Removal, Bottom Screw Removal: шаг 2, изображение 1 из 1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Optical Drive Removal, Top and Side Screws: шаг 3, изображение 1 из 3 eMac Optical Drive Removal, Top and Side Screws: шаг 3, изображение 2 из 3 eMac Optical Drive Removal, Top and Side Screws: шаг 3, изображение 3 из 3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Optical Drive Removal, Power Button Cable: шаг 4, изображение 1 из 2 eMac Optical Drive Removal, Power Button Cable: шаг 4, изображение 2 из 2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Optical Drive Removal, Shell Removal: шаг 5, изображение 1 из 1
    • Now the entire shell can be removed from the computer.
  6. eMac Optical Drive Removal, Panel Removal: шаг 6, изображение 1 из 3 eMac Optical Drive Removal, Panel Removal: шаг 6, изображение 2 из 3 eMac Optical Drive Removal, Panel Removal: шаг 6, изображение 3 из 3
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  7. eMac Optical Drive Removal, Cable Removal: шаг 7, изображение 1 из 2 eMac Optical Drive Removal, Cable Removal: шаг 7, изображение 2 из 2
    • The eMac uses a standard 5.25" IDE optical drive. Most off-the-shelf drives should work as a replacement with minor modification. The jumper setting for the drive should be "CS".
    • Start by disconnecting the IDE and power cables from the drive.
  8. eMac Optical Drive Removal, Screw Removal: шаг 8, изображение 1 из 2 eMac Optical Drive Removal, Screw Removal: шаг 8, изображение 2 из 2
    • The drive is held in by two phillips #2 screws on each side. Remove these.
  9. eMac Optical Drive Removal, Drive Removal: шаг 9, изображение 1 из 2 eMac Optical Drive Removal, Drive Removal: шаг 9, изображение 2 из 2
    • The drive should now come free.
Заключение
4 участников успешно повторили данное руководство.
Chris Green
Участник с: 10/11/09
36 978 Репутация
Автор 49 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 528 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 25
За всё время: 2,248
