Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 1 —
Тип шага:
Перетащите чтобы изменить порядок
Measure top and bottom of damaged section.
When replacing a corner bead, you must measure at least 1.5 inches from the corner.
Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
You can even use the putty knife if the damaged section is not too long.
Mark with a pencil, or cut lightly with utility knife.
Use caution when using the utility knife as the blade is very sharp and may cause an injury.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
