Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Помощь
Редактирование шага 6 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 2 guides that include this step.
Тип шага:
Перетащите чтобы изменить порядок
Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel the longer piece of backing out from behind the strip.
If the top half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
