Введение
If your Eufy RoboVac G32 Pro is not properly cleaning debris from your floor, use this guide to replace the rolling brush.
The rolling brush is designed to sweep debris into the path of the vacuum. If the brush stops rotating, is getting stuck, or is no longer picking up debris, this is a good indicator for replacement. Replacement rolling brushes can be found here.
Make sure your device is turned off.
Flip the device upside down on a flat surface.
Press the clips at the bottom of the device that are indicated by the downward facing arrows.
Take off the rolling brush cover.
