eufy Security SpaceView Monitor Motherboard Replacement
Выберете то, что вам нужно
  1. eufy Security SpaceView Monitor Motherboard Replacement, Display Assembly: шаг 1, изображение 1 из 2 eufy Security SpaceView Monitor Motherboard Replacement, Display Assembly: шаг 1, изображение 2 из 2
    • Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Motherboard Replacement: шаг 2, изображение 1 из 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Motherboard Replacement, Screen: шаг 3, изображение 1 из 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Motherboard Replacement: шаг 4, изображение 1 из 2 eufy Security SpaceView Monitor Motherboard Replacement: шаг 4, изображение 2 из 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Motherboard Replacement: шаг 5, изображение 1 из 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
  6. eufy Security SpaceView Monitor Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 2 eufy Security SpaceView Monitor Motherboard Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
  7. eufy Security SpaceView Monitor Motherboard Replacement: шаг 7, изображение 1 из 3 eufy Security SpaceView Monitor Motherboard Replacement: шаг 7, изображение 2 из 3 eufy Security SpaceView Monitor Motherboard Replacement: шаг 7, изображение 3 из 3
    • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
    • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
    • Lift the motherboard and disconnect the antenna connector from its port.
    • The motherboard is free from the housing and can be replaced.
Заключение
ZFarley
Участник с: 10/31/23
395 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Участник UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 68
