Помощь
Dell Inspiron N4010 Hard Disk Drive Replacement
Replacing the Hard Drive for a laptop can speed it up and add more storage.
  • Автор: Jonathan Sellier
  • Времени уйдёт: 25 - 30 мин.
  • Сложность: Средняя
Replacing the Hard Drive for a laptop can speed it up and add more storage. Keep in mind that after replacing the hard drive you must reinstall your Operating System. Locate all product keys needed before performing this guide.
Разделы
Шаг 1 Hard Disk Drive  ¶
Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
  • Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
Шаг 2  ¶
Slide the hard drive towards the center of the motherboard. The hard drive should come away from the motherboard.
Шаг 2  ¶
  • Slide the hard drive towards the center of the motherboard.
  • The hard drive should come away from the motherboard.
Шаг 3  ¶
Undo the 2 screws with the #0 Phillips head driver on either side of the hard drive assembly.
Шаг 3  ¶
  • Undo the 2 screws with the #0 Phillips head driver on either side of the hard drive assembly.
Шаг 4  ¶
Slide the assembly off of the hard drive. Slide the assembly off of the hard drive.
Шаг 4  ¶
  • Slide the assembly off of the hard drive.
