Помощь
Aquaris M5 back Cover Replacement
This guide shows you how to take of the back cover of your bq Aquaris M5.
  • Автор: Theo Mat
  • Времени уйдёт: 5 мин.
  • Сложность: Очень просто
Use this guide to take off the back cover of your bq Aquaris M5.
Инструменты
Шаг 1 Back Cover  ¶
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone. Between the 2 SIM card slots is a good place to start.
Шаг 1 Back Cover  ¶
  • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
  • Between the 2 SIM card slots is a good place to start.
  • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Шаг 2  ¶
Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge. Slide around the corner and along the top edge, to also disconnect these clips.
Шаг 2  ¶
  • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
  • Slide around the corner and along the top edge, to also disconnect these clips.
Шаг 3  ¶
Be careful not to bend the back cover too hard to prevent some of the clips breaking. Grab the back cover by the loosened edge. Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
Шаг 3  ¶
  • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
  • Grab the back cover by the loosened edge.
  • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
  • Take off the back cover.
