Помощь
Google Pixelbook Touchpad Replacement
How to replace a Google Pixelbook touchpad.
  • Автор: Derrick Unger
  • Времени уйдёт: 15 - 20 мин.
  • Сложность: Средняя
Before starting this replacement, make sure you've read the troubleshooting guide to verify that the touchpad needs to be replaced. There are fragile ribbon connectors being removed in this guide, so proceed with caution!
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Touchpad  ¶
Once the back panel is out of the way,  use the T3 Torx screwdriver to turn both the  2.0mm and large 3.0mm gold screws  from the touchpad. Once the back panel is out of the way,  use the T3 Torx screwdriver to turn both the  2.0mm and large 3.0mm gold screws  from the touchpad. Once the back panel is out of the way,  use the T3 Torx screwdriver to turn both the  2.0mm and large 3.0mm gold screws  from the touchpad.
Шаг 1 Touchpad  ¶
  • Once the back panel is out of the way, use the T3 Torx screwdriver to turn both the 2.0mm and large 3.0mm gold screws from the touchpad.
Шаг 2  ¶
Gently pull out the ribbon connector either by using tweezers or your fingers to pull the cord out and up. Gently pull out the ribbon connector either by using tweezers or your fingers to pull the cord out and up. Gently pull out the ribbon connector either by using tweezers or your fingers to pull the cord out and up.
Шаг 2  ¶
  • Gently pull out the ribbon connector either by using tweezers or your fingers to pull the cord out and up.
Шаг 3  ¶
Use the nylon spudger to push the touchpad out of the laptop by inserting the point into the hole near the edge of the laptop. As the metal plates with the screws tilt upwards, use your hand to catch the falling touchpad and remove it.
Шаг 3  ¶
  • Use the nylon spudger to push the touchpad out of the laptop by inserting the point into the hole near the edge of the laptop.
  • As the metal plates with the screws tilt upwards, use your hand to catch the falling touchpad and remove it.
