Помощь
Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement
Follow these steps to replace the control panel circuit board behind the front face of the Pioneer Elite Pro-R06U.
  • Автор: Cody Carter
  • Времени уйдёт: 25 - 30 мин.
  • Сложность: Средняя
A faulty or defective front control panel may cause buttons on the media receiver to be unresponsive. Replacing the circuit board should resolve issues with the front controls and buttons.
Шаг 1 Control Panel Circuit Board  ¶
Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
Шаг 2  ¶
Remove the two 6.5 mm Phillips screws on the back of the device casing.
Шаг 2  ¶
  • Remove the two 6.5 mm Phillips screws on the back of the device casing.
Шаг 3  ¶
Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
Шаг 3  ¶
  • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
Шаг 4  ¶
Unlatch the three plastic connectors on the top of the receiver that hold the front panel to the device casing.
Шаг 4  ¶
  • Unlatch the three plastic connectors on the top of the receiver that hold the front panel to the device casing.
Шаг 5  ¶
The connectors on the bottom of the device may be very stiff and could require the use of a plastic prying tool.
Шаг 5  ¶
  • The connectors on the bottom of the device may be very stiff and could require the use of a plastic prying tool.
  • Carefully flip the device over and unlatch the three plastic connectors that hold the front panel to the bottom of the device casing.
Шаг 6  ¶
Grip and unplug the ribbon connector that connects the front circuit board to the device.
Шаг 6  ¶
  • Grip and unplug the ribbon connector that connects the front circuit board to the device.
Шаг 7  ¶
Unscrew the three 1/4 Phillips head screws on the back of the front circuit board.
Шаг 7  ¶
  • Unscrew the three 1/4 Phillips head screws on the back of the front circuit board.
Шаг 8  ¶
Grip the circuit board and slide towards the front side of the plastic casing. Lift upwards to remove the circuit board from the front panel.
Шаг 8  ¶
  • Grip the circuit board and slide towards the front side of the plastic casing.
  • Lift upwards to remove the circuit board from the front panel.
