Помощь
Alienware M11x Display Assembly Replacement
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
  • Автор: darrius
  • Времени уйдёт: 20 - 25 мин.
  • Сложность: Просто
In this guide, we will be showing you how to remove and replace the Display Assembly.
Инструменты
Шаг 1 Introduction  ¶
WARNING:  Before working inside your computer, read the safety information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • NOTE: Dell or Alienware does not guarantee compatibility or provide support for hard drives from sources other than Dell.
  • NOTE: If you are installing a hard drive from a source other than Dell or Alienware, you need to install an operating system, drivers, and utilities on the new hard drive.
Шаг 2 Loosen the Screws  ¶
Loosen the two captive screws that secure the hard-drive assembly to the computer base.
  • Loosen the two captive screws that secure the hard-drive assembly to the computer base.
Шаг 3 Disconnecting the Hard-Drive  ¶
Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
  • Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
Шаг 4 Lifting the Hard-Drive Assembly  ¶
Lift the hard-drive assembly out of the computer base.
  • Lift the hard-drive assembly out of the computer base.
Шаг 5 Removing the Screws from the Hard-Drive  ¶
Remove the four screws that secure the hard drive to the hard-drive bracket.
  • Remove the four screws that secure the hard drive to the hard-drive bracket.
Шаг 6 Removing the Bracket  ¶
Lift the hard drive away from the hard-drive bracket.
  • Lift the hard drive away from the hard-drive bracket.
Шаг 7 Placing the Hard-Drive  ¶
Place the NEW hard drive in the hard-drive bracket.
  • Place the NEW hard drive in the hard-drive bracket.
Шаг 8 Replace the Screws  ¶
Replace the four screws that secure the hard-drive to the hard-drive bracket.
  • Replace the four screws that secure the hard-drive to the hard-drive bracket.
Шаг 9 Placing the Hard-Drive  ¶
Place the hard-drive assembly in the computer base.
  • Place the hard-drive assembly in the computer base.
Шаг 10 Connecting the Hard-Drive Assembly  ¶
Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
  • Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
Шаг 11 Securing the Screws  ¶
Tighten the two captive screws that secure the hard-drive assembly to the computer base.
  • Tighten the two captive screws that secure the hard-drive assembly to the computer base.
