Помощь
LG-A275 Speaker Replacement
В работе
В работе
Это руководство находится в процессе написания. Чтобы видеть последние изменения, периодически обновляйте страницу.
How to replace the LG-A275 speaker.
  • Автор: Nathanael Knight
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's speaker.
Разделы
Инструменты
Шаг 1 Speaker  ¶
Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone. Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics. Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
Шаг 1 Speaker  ¶
  • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
  • Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
Шаг 2  ¶
After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail. Be careful when doing this to avoid breaking the phone plastics, it should release easily. Be careful when doing this to avoid breaking the phone plastics, it should release easily.
Шаг 2  ¶
  • After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail.
  • Be careful when doing this to avoid breaking the phone plastics, it should release easily.
Шаг 3  ¶
Lastly remove the speaker using the plastic opening tool. Lastly remove the speaker using the plastic opening tool. Lastly remove the speaker using the plastic opening tool.
Шаг 3  ¶
  • Lastly remove the speaker using the plastic opening tool.
