Помощь
Mac mini Model A1283 RAM Replacement
Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
  • Автор: Walter Galan
  • Времени уйдёт: 20 мин. - 1 час
  • Сложность: Средняя
Accessing the RAM requires the removal of the internal frame.
Разделы
Инструменты
Шаг 1 RAM  ¶
Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. Pull the RAM chip directly out from its connector.
Шаг 1 RAM  ¶
  • Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the RAM chip directly out from its connector.
  • If there are two RAM chips installed, repeat the above procedure for the second chip.
