Помощь
Huawei Union Screen Replacement
This guide will show you how to replace the Screen for the Huawei Union in a few short and simple steps.
  • Автор: Brittany Achor
  • Времени уйдёт: 45 мин. - 1 час
  • Сложность: Средняя
Use this guide if your Huawei Union will not power on when the power button is pressed and you need to replace the screen.
Разделы
Инструменты
Шаг 1 Screen  ¶
Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
Шаг 1 Screen  ¶
  • Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
Шаг 2  ¶
Wedge an opening pick underneath the screen and slowly work your way around the screen. Wedge an opening pick underneath the screen and slowly work your way around the screen.
Шаг 2  ¶
  • Wedge an opening pick underneath the screen and slowly work your way around the screen.
Шаг 3  ¶
Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point. With each pass, move the Opening Pick further to complete separation.
Шаг 3  ¶
  • Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point.
  • With each pass, move the Opening Pick further to complete separation.
Шаг 4  ¶
Once screen is sufficiently separated,  holding the sides of the frame firmly, use the Spudger to press through the  small access window to the screen at the top let and completely separate the screen from the frame. Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over. Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
Шаг 4  ¶
  • Once screen is sufficiently separated, holding the sides of the frame firmly, use the Spudger to press through the small access window to the screen at the top let and completely separate the screen from the frame.
  • Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over.
  • Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
Шаг 5  ¶
Pull screen away from frame making sure the ribbon cable stays attached.
Шаг 5  ¶
  • Pull screen away from frame making sure the ribbon cable stays attached.
