Помощь
LG Risio Midframe Replacement
This guide will give you walk through as to how to replace the midframe of the LG Risio.
  • Автор: Kevin Garcia
  • Времени уйдёт: 3 мин.
  • Сложность: Средняя
Use this guide if you are looking to gain access to the LG Risio Motherboard or other components inside the device.
Разделы
Инструменты
Шаг 1 Midframe  ¶
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Шаг 1 Midframe  ¶
  • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Шаг 2  ¶
Remove the eight Phillips #0 screws from the internal support frame. Remove the eight Phillips #0 screws from the internal support frame.
Шаг 2  ¶
  • Remove the eight Phillips #0 screws from the internal support frame.
Шаг 3  ¶
Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
Шаг 3  ¶
  • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
Шаг 4  ¶
Using your hand, pick up the midframe to  separate it from the phone.
Шаг 4  ¶
  • Using your hand, pick up the midframe to separate it from the phone.
  • If the midframe does not want to lift off, go back and repeat step 6.
