Помощь
Lenovo Thinkpad X201 Tablet Keyboard Replacement
Use this guide to replace the keyboard in your Lenovo ThinkPad X201 Tablet.
  • Автор: Thomas Donahue
  • Времени уйдёт: 10 - 15 мин.
  • Сложность: Средняя
This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
Разделы
Инструменты
Шаг 1 Keyboard  ¶
Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
Шаг 1 Keyboard  ¶
  • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
Шаг 2  ¶
Using your fingers push keyboard forward so it is closer to the screen than it was before
Шаг 2  ¶
  • Using your fingers push keyboard forward so it is closer to the screen than it was before
Шаг 3  ¶
Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Шаг 3  ¶
  • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
