Помощь
Lenovo ThinkPad X61 RAM Replacement
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
Use this guide to help you replace the RAM in your ThinkPad.
  • Автор: Ryan McCarthy
  • Времени уйдёт: 5 мин.
  • Сложность: Средняя
Инструменты
Шаг 1 RAM  ¶
First flip your device over so its bottom is facing up. Next, locate where the two Philip #00  screws are marked in the image, and unscrew them as shown. Next, locate where the two Philip #00  screws are marked in the image, and unscrew them as shown.
Шаг 1 RAM  ¶
  • First flip your device over so its bottom is facing up.
  • Next, locate where the two Philip #00 screws are marked in the image, and unscrew them as shown.
Шаг 2  ¶
Now with the loosened screws, you can easily pull back the metal compartment cover to get to where RAM is stored.
Шаг 2  ¶
  • Now with the loosened screws, you can easily pull back the metal compartment cover to get to where RAM is stored.
Шаг 3  ¶
After opening up the compartment, you simply pull out the two RAM units and replace them with the new RAM.
Шаг 3  ¶
  • After opening up the compartment, you simply pull out the two RAM units and replace them with the new RAM.
