Помощь
ZTE ZMax Pro Display Assembly Replacement
How to replace the display assembly of the ZTE ZMax Pro model Z981.
  • Автор: Nicholas Leacox
  • Времени уйдёт: 35 - 40 мин.
  • Сложность: Средняя
This guide will show you how to replace the screen display on the device. You will need a plastic opening tool, tweezers, two opening picks, a Phillip s #00 screwdriver, and a heat gun to complete this guide.
Разделы
Инструменты
Шаг 1 Display Assembly  ¶
Disconnect the digital flex cable connector, located at the top left of the phone, using a pair of tweezers.
  • Disconnect the digital flex cable connector, located at the top left of the phone, using a pair of tweezers.
Шаг 2  ¶
Using your fingers peel up the LCD flex cables. These cables are black and flat. Using your fingers peel up the LCD flex cables. These cables are black and flat. Using your fingers peel up the LCD flex cables. These cables are black and flat.
Шаг 2  ¶
  • Using your fingers peel up the LCD flex cables. These cables are black and flat.
Шаг 3  ¶
Peel the flex cables off where they are attached to the frame. Peel the flex cables off where they are attached to the frame.
Шаг 3  ¶
  • Peel the flex cables off where they are attached to the frame.
Шаг 4  ¶
Insert a plastic opening tool between the screen and the rear case and separate it carefully, starting at the bottom. Insert a plastic opening tool between the screen and the rear case and separate it carefully, starting at the bottom.
Шаг 4  ¶
  • Insert a plastic opening tool between the screen and the rear case and separate it carefully, starting at the bottom.
Шаг 5  ¶
Push the digitizer flex cable through the hole in the frame to separate the LCD from the phone. Push the digitizer flex cable through the hole in the frame to separate the LCD from the phone.
Шаг 5  ¶
  • Push the digitizer flex cable through the hole in the frame to separate the LCD from the phone.
