Помощь
RedOctane X-Plorer Auxiliary Port Replacement
Рекомендуемое руководство ученика
Это руководство стало результатом напряженной работой наших удивительных студентов, и сотрудники iFixit посчитали его очень крутым.
This guide will show you how to replace the auxiliary port on the RedOctane X-Plorer located at the bottom of the guitar.
  • Автор: Riley
  • Времени уйдёт: 20 мин.
  • Сложность: Просто
You can easily access the auxiliary port through the guitar neck. This guide will show you how to replace the auxiliary port located at the bottom of the guitar.
Разделы
Инструменты
Шаг 1 Auxiliary Port  ¶
Remove the two 10mm Phillips #1 screws from the auxiliary port board using a  screwdriver. Gently lift up on the auxiliary port to remove it from the case. Gently lift up on the auxiliary port to remove it from the case.
  • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
  • Gently lift up on the auxiliary port to remove it from the case.
