Помощь
TI-Nspire Screen Replacement
Буллеты!
Буллеты!
Использование примечания и разного цвета шрифта, в частности использование нумерации, поможет сделать это руководство более понятным!
This guide will aid in replacing a cracked screen for TI-Nspire Calculators.
  • Автор: Alan Wong
  • Времени уйдёт: 20 - 30 мин.
  • Сложность: Сложно
Replace the cracked or damaged screen of TI-Nspire Calculator to enable the display for more efficient use of the device.
Шаг 1 TI-Nspire Screen  ¶
Remove the four batteries to help prevent electrical shorts in later steps.
  • Remove the four batteries to help prevent electrical shorts in later steps.
Шаг 2  ¶
Remove the four 0.165 inch screws at the middle and bottom of the motherboard with the screwdriver.
Шаг 2  ¶
  • Remove the four 0.165 inch screws at the middle and bottom of the motherboard with the screwdriver.
  • Use a Phillips #000 screwdriver to remove the two 0.349 inch screws at the top corners of the motherboard.
Шаг 3  ¶
Holding the calculator with the motherboard face-up, gently press the screen up about 3/8 inch and towards the motherboard. Remove the motherboard and screen together and set aside.
Шаг 3  ¶
  • Holding the calculator with the motherboard face-up, gently press the screen up about 3/8 inch and towards the motherboard.
  • Remove the motherboard and screen together and set aside.
Шаг 4  ¶
Use a flathead screwdriver to gently pry the orange ribbon away from the screen.
Шаг 4  ¶
  • Use a flathead screwdriver to gently pry the orange ribbon away from the screen.
