Помощь
How to Remove the Back Plate of a TI-NSpire
Буллеты!
Буллеты!
Использование примечания и разного цвета шрифта, в частности использование нумерации, поможет сделать это руководство более понятным!
This guide will teach you how to remove the back plate of a TI-NSpire.
  • Автор: John Baek
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
Removing the back plate will allow access to the inner circuitry of the calculator, which is necessary for other troubleshooting guides.
Шаг 1 TI-Nspire Back Plate  ¶
Place the calculator screen facing down with the back plate facing up.
  • Place the calculator screen facing down with the back plate facing up.
Шаг 2  ¶
With a #000 Philips screwdriver, remove the 6 x .286 inch screw drivers located at the top, middle, and bottom of the calculator.
Шаг 2  ¶
  • With a #000 Philips screwdriver, remove the 6 x .286 inch screw drivers located at the top, middle, and bottom of the calculator.
Шаг 3  ¶
Locate the latch toward the bottom of the calculator.
Шаг 3  ¶
  • Locate the latch toward the bottom of the calculator.
Шаг 4  ¶
Slide the latch to the right to release the keypad. At the same time, pull the keypad down.
Шаг 4  ¶
  • Slide the latch to the right to release the keypad.
  • At the same time, pull the keypad down.
Шаг 5  ¶
Locate and remove the screw near the bottom of the calculator on the front side.
Шаг 5  ¶
  • Locate and remove the screw near the bottom of the calculator on the front side.
  • The screw is behind where the keyboard normally sits.
Шаг 6  ¶
Now, turn the calculator over so the back plate faces up. Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner. The prying order is arbitrary. The important part is for it to be sequential across the length of the calculator.
Шаг 6  ¶
  • Now, turn the calculator over so the back plate faces up.
  • Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner.
  • The prying order is arbitrary. The important part is for it to be sequential across the length of the calculator.
  • Repeat the prying step on the right side, moving along the perimeter of the calculator.
  • Repeat the prying step on the top right corner.
Шаг 7  ¶
Use your hands to manually separate the now loosened back plate from the calculator.
Шаг 7  ¶
  • Use your hands to manually separate the now loosened back plate from the calculator.
