Помощь
Skateboard Skateboard Trucks Replacement
Отсутствуют необходимые  руководства
В этом руководстве не хватает информации о том, как начать процесс. Сделай необходимое руководство!
This guide will help you correctly install the trucks for your skateboard.
  • Автор: Cameron Nye
  • Времени уйдёт: 15 - 25 мин.
  • Сложность: Просто
Be sure that you have installed grip tape on your board before installing your skateboard trucks. If you have not, please see the Grip Tape Application guide. Also be aware of the type of hardware you have. This will decide whether you need an Allen Wrench or a Phillips Head Screwdriver.
Инструменты
Связанные запчасти
Шаг 1 Skateboard Trucks  ¶
Insert bolt hardware through the factory drilled holes from the top side of the skateboard. If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
  • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
Шаг 2  ¶
Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
Шаг 2  ¶
  • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
Шаг 3  ¶
Hand tighten the nut hardware onto all four bolts.
Шаг 3  ¶
  • Hand tighten the nut hardware onto all four bolts.
Шаг 4  ¶
While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver.  Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
Шаг 4  ¶
  • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
  • Repeat steps 1 - 6 to install the second truck.
