Помощь
iPod Touch 2nd Generation Logic Board Replacement
Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
Restore life to your iPod Touch 2nd Generation by replacing the logic board.
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Logic Board  ¶
Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
Шаг 1 Logic Board  ¶
  • Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
  • Remove the metal display tray and set it aside.
  • Lay the battery flat in the rear panel.
Шаг 2  ¶
Remove the single Phillips screw securing the gold pressure contact to the logic board. Use a pair of tweezers to lift the Phillips screw out of the logic board.
Шаг 2  ¶
  • Remove the single Phillips screw securing the gold pressure contact to the logic board.
  • Use a pair of tweezers to lift the Phillips screw out of the logic board.
Шаг 3  ¶
Remove the following three Phillips screws securing the logic board to the rear panel:
Шаг 3  ¶
  • Remove the following three Phillips screws securing the logic board to the rear panel:
  • One 1.9 mm screw
  • Two 2.3 mm screws
  • The darker screw belongs in the screw hole next to the dock connector.
Шаг 4  ¶
Using the tip of a spudger, flip up the control button ribbon cable retaining flap. Be sure you are prying up on the retaining flap, not the socket itself.
Шаг 4  ¶
  • Using the tip of a spudger, flip up the control button ribbon cable retaining flap.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • This socket is found under the battery.
Шаг 5  ¶
Use a pair of tweezers to pull the control button ribbon cable straight out of its socket. Use a pair of tweezers to pull the control button ribbon cable straight out of its socket.
Шаг 5  ¶
  • Use a pair of tweezers to pull the control button ribbon cable straight out of its socket.
Шаг 6  ¶
Use the tip of a spudger to peel back the protective rubber grommet to reveal a hidden Phillips screw. It is not necessary to completely remove this flap.
Шаг 6  ¶
  • Use the tip of a spudger to peel back the protective rubber grommet to reveal a hidden Phillips screw.
  • It is not necessary to completely remove this flap.
  • Remove the hidden Phillips screw.
Шаг 7  ¶
Remove the two remaining Phillips screws securing the upper logic board to the rear panel.
Шаг 7  ¶
  • Remove the two remaining Phillips screws securing the upper logic board to the rear panel.
Шаг 8  ¶
Use the flat end of a spudger to separate the Wi-Fi ribbon cable from the adhesive securing it to the rear panel.
Шаг 8  ¶
  • Use the flat end of a spudger to separate the Wi-Fi ribbon cable from the adhesive securing it to the rear panel.
Шаг 9  ¶
Insert the flat end of a spudger between the metal rear panel and Wi-Fi ribbon cable to further loosen the adhesive along the length of the cable.
Шаг 9  ¶
  • Insert the flat end of a spudger between the metal rear panel and Wi-Fi ribbon cable to further loosen the adhesive along the length of the cable.
Шаг 10  ¶
Use your hands to continue peeling the Wi-Fi ribbon off the rear panel.
Шаг 10  ¶
  • Use your hands to continue peeling the Wi-Fi ribbon off the rear panel.
Шаг 11  ¶
Pull the small upper portion of the logic board away from the top edge of the Touch to separate it from the rear panel. Allow the board to rest on the outside of the rear panel.
Шаг 11  ¶
  • Pull the small upper portion of the logic board away from the top edge of the Touch to separate it from the rear panel.
  • Allow the board to rest on the outside of the rear panel.
Шаг 12  ¶
Gently pull the lower portion of the logic board away from the bottom edge of the rear panel.
Шаг 12  ¶
  • Gently pull the lower portion of the logic board away from the bottom edge of the rear panel.
Шаг 13  ¶
Carefully lift the logic board assembly out of the rear case, minding any edges that may get caught. Carefully lift the logic board assembly out of the rear case, minding any edges that may get caught.
Шаг 13  ¶
  • Carefully lift the logic board assembly out of the rear case, minding any edges that may get caught.
