Помощь
Техника: 2002-2008 Dodge Ram 1500 Fuse Replacement
Check for blown fuses and replace them.
  • Автор: Michael Saggese
  • Времени уйдёт: 10 мин.
  • Сложность: Просто
This guide demonstrates how to remove and replace fuses for your Dodge truck.
Инструменты
Связанные запчасти
Шаг 1 2002-2008 Dodge Ram 1500 Fuse Replacement  ¶
Open the hood by pulling the hood lever in the driver-side footwell. Reach under the center of the grille and press the hood latch. Reach under the center of the grille and press the hood latch.
  • Open the hood by pulling the hood lever in the driver-side footwell.
  • Reach under the center of the grille and press the hood latch.
Шаг 2  ¶
Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge. Unscrew the plastic nut that holds the cover of the fusebox in place.
Шаг 2  ¶
  • Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
  • Unscrew the plastic nut that holds the cover of the fusebox in place.
Шаг 3  ¶
Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check. Locate the fuse grabber. The fuse grabber is located near the front of the fusebox. Remove the fuse grabber from its holder.
Шаг 3  ¶
  • Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
  • Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
  • Remove the fuse grabber from its holder.
Шаг 4  ¶
Use the fuse grabber to carefully pinch the fuse. Pull the desired fuse out.
Шаг 4  ¶
  • Use the fuse grabber to carefully pinch the fuse.
  • Pull the desired fuse out.
  • Be sure to replace each blown fuse with a fuse of the correct current rating and size. Serious damage can occur if the wrong fuse is used.
