Помощь
Shark DuoClean Powered Lift-Away Speed Drive Belt Replacement
How to replace the drive belt in the Shark DuoClean Powered Lift-Away Speed.
  • Автор: Catie Halvorsen
  • Времени уйдёт: 1 час
  • Сложность: Средняя
If the drive belt is out of place or jammed, use this guide to replace the drive belt. You will need the T10 and T20 Torx screwdrivers.
Разделы
Инструменты
Шаг 1 Drive Belt  ¶
Use the T20 screwdriver to remove the four 17 mm screws by turning counterclockwise. Use the T20 screwdriver to remove the four 17 mm screws by turning counterclockwise.
Шаг 1 Drive Belt  ¶
  • Use the T20 screwdriver to remove the four 17 mm screws by turning counterclockwise.
Шаг 2  ¶
Use the T20 screwdriver to remove the six 19 mm screws by turning counterclockwise. Use the T20 screwdriver to remove the one 12 mm screw by turning counterclockwise.
Шаг 2  ¶
  • Use the T20 screwdriver to remove the six 19 mm screws by turning counterclockwise.
  • Use the T20 screwdriver to remove the one 12 mm screw by turning counterclockwise.
  • Use the T10 screwdriver to remove the four 14 mm screws by turning counterclockwise.
Шаг 3  ¶
Use the spudger tool to pry off the red plastic corner cap. Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time. Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time.
Шаг 3  ¶
  • Use the spudger tool to pry off the red plastic corner cap.
  • Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time.
Шаг 4  ¶
Remove the red cover by lifting upward.
Шаг 4  ¶
  • Remove the red cover by lifting upward.
Шаг 5  ¶
Remove the light fixture by lifting it up.
Шаг 5  ¶
  • Remove the light fixture by lifting it up.
Шаг 6  ¶
Use the spudger to detach the orange drive belt compartment from the vacuum. Remove the orange drive belt compartment from the vacuum by lifting it upwards.
Шаг 6  ¶
  • Use the spudger to detach the orange drive belt compartment from the vacuum.
  • Remove the orange drive belt compartment from the vacuum by lifting it upwards.
Шаг 7  ¶
Pull outward on the smaller drive belt to remove it.
Шаг 7  ¶
  • Pull outward on the smaller drive belt to remove it.
  • Pull outward on the larger drive belt to remove it.
  • The smaller drive belt must be removed first in order to remove the second larger belt.
