Помощь
Samsung Galaxy Tab E 8.0 Screen Replacement
Живописный маршрут
Живописный маршрут
Это руководство не является наиболее эффективным способом отремонтировать устройство. Но все же может быть полезным в некоторых обстоятельствах.
This guide will show you how to replace the screen on the Samsung Galaxy Tab E 8.0.
  • Автор: Chrissy B
  • Времени уйдёт: 15 - 45 мин.
  • Сложность: Средняя
The screen of the Samsung Galaxy Tab E 8.0 may become damaged if the device is dropped or struck by a hard object. This guide shows how to replace the tablet's screen, which is attached to the front panel.
Разделы
Шаг 1 Screen  ¶
Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device. Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
Шаг 1 Screen  ¶
  • Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
  • Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
  • The metal spudger may be needed to get between the screen.
  • The metal spudger may cause more damage to the screen if used with force.
Шаг 2  ¶
Use the metal spudger to get between the device and the internal screen. Pry out the screen from the device.
Шаг 2  ¶
  • Use the metal spudger to get between the device and the internal screen.
  • Pry out the screen from the device.
